[postgis-tickets] [PostGIS] #2564: Implement the inverse of the ST_AsLatLonText function
PostGIS trac at osgeo.org
Fri Dec 13 08:18:02 PST 2013
 Reporter:  andrewxhill  |       Owner:  pramsey
     Type:  enhancement  |      Status:  new
 Priority:  low          |   Milestone:  PostGIS 2.1.2
Component:  postgis      |     Version:  2.1.x
 Keywords:               |
 It would be helpful (likely to a number of applications and users) if
 PostGIS had a function to go from DMS to geometry.
 For example being able to perform these two variations would be a great
 start,
 geometry pt ST_FromLatLonText(text, text);
 example:
 SELECT ST_FromLatLonText('31°55'12.000"N','98°58'48.000"W');
 and
 geometry pt ST_FromLatLonText(text);
 example:
 SELECT ST_FromLatLonText('31°55'12.000"N 98°58'48.000"W');
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2564>
