[postgis-tickets] [PostGIS] #2570: Create version of ST_RotateX with pointOrigin like ST_Rotate()
PostGIS trac at osgeo.org
Sat Dec 14 22:22:35 PST 2013
 Reporter:  smathermather  |       Owner:  pramsey
     Type:  patch          |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS 2.1.2
Component:  postgis        |     Version:  2.1.x
 Keywords:                 |
 geometry ST_RotateX(geometry geomA, float rotRadians, geometry
 pointOrigin)
 -- Function: st_rotatex(geometry, double precision, geometry)
 CREATE OR REPLACE FUNCTION ST_RotateX(geomA geometry, rotRadians double
 precision, pointOrigin geometry)
   RETURNS geometry AS
 $BODY$
 -- Transform geometry to nullsville (0,0,0) so rotRadians will take place
 around the pointOrigin
 WITH transformed AS (
     SELECT ST_Translate(geomA, -1 * ST_X(pointOrigin), -1 *
 ST_Y(pointOrigin), -1 * ST_Z(pointOrigin)) AS the_geom
 -- Rotate in place
 rotated AS (
     SELECT ST_RotateX(the_geom, rotRadians) AS the_geom FROM transformed
 -- Translate back home
 rotTrans AS (
     SELECT ST_Translate(the_geom, ST_X(pointOrigin), ST_Y(pointOrigin),
         FROM rotated
 -- profit
 SELECT the_geom from rotTrans
 $BODY$
   LANGUAGE sql VOLATILE
   COST 100;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2570>
