[postgis-tickets] [PostGIS] #2571: Create version of ST_RotateY with pointOrigin like ST_Rotate()
trac at osgeo.org
Sat Dec 14 22:23:59 PST 2013
Reporter: smathermather | Owner: pramsey
Type: patch | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: postgis | Version: 2.1.x
Keywords: |
geometry ST_RotateY(geometry geomA, float rotRadians, geometry
pointOrigin)
-- Function: ST_RotateY(geometry, double precision, geometry)
CREATE OR REPLACE FUNCTION ST_RotateY(geomA geometry, rotRadians double
precision, pointOrigin geometry)
RETURNS geometry AS
$BODY$
-- Transform geometry to nullsville (0,0,0) so rotRadians will take place
around the pointOrigin
WITH transformed AS (
SELECT ST_Translate(geomA, -1 * ST_X(pointOrigin), -1 *
ST_Y(pointOrigin), -1 * ST_Z(pointOrigin)) AS the_geom
-- Rotate in place
rotated AS (
SELECT ST_RotateY(the_geom, rotRadians) AS the_geom FROM transformed
-- Translate back home
rotTrans AS (
SELECT ST_Translate(the_geom, ST_X(pointOrigin), ST_Y(pointOrigin),
FROM rotated
-- profit
SELECT the_geom from rotTrans
$BODY$
LANGUAGE sql VOLATILE
COST 100;
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2571>
