[postgis-tickets] [PostGIS] #2588: GeometryCollection constructor parse defect for sub geometries (POINTM, POLYGONM, ...) of GEOMETRYCOLLECTIONM
PostGIS trac at osgeo.org
Mon Dec 23 12:30:50 PST 2013
(POINTM,POLYGONM,...) of GEOMETRYCOLLECTIONM
 Reporter:  bergun                                    |       Owner:  delawen
     Type:  defect                                    |      Status:  new
 Priority:  medium                                    |   Milestone:  PostGIS 2.2.0
Component:  java                                      |     Version:  trunk
 Keywords:  GEOMETRYCOLLECTIONM jdbc POINTM POLYGONM  |
 I create a GeometryCollection as below
 GeometryCollection coll = new GeometryCollection(
                             "SRID=-1;GEOMETRYCOLLECTIONM(POINTM(10 10
 100),LINESTRINGM(0 50 100, 100 50 100),POLYGONM((25 25 100,75 25 100,75 75
 100,25 75 100,25 25 100),(45 45 100,55 45 100,55 55 100,45 55 100,45 45
 100)))"));
 when I reprint the coll.toString() I see that my geom string is changed to
 below :
 "SRID=-1;GEOMETRYCOLLECTIONM(POINT(10 10 100),LINESTRING(0 50 100, 100 50
 100),POLYGON((25 25 100,75 25 100,75 75 100,25 75 100,25 25 100),(45 45
 100,55 45 100,55 55 100,45 55 100,45 45 100)))"
 As you can see GEOMETRYCOLLECTIONM is preserved but POINTM LINESTRINGM and
 POLYGONM is changed to POINT LINESTRING and POLYGON . And because of this
 I get cannot mix dimensionality when I am trying to insert this geom to
 database.
 I have tried this with postgis jdbc driver 1.1.5; 1.3.3 and 2.0.1
 versions.
 Similar issue http://trac.osgeo.org/postgis/ticket/724  was open and
 resolved for server side postgis extension.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2588>
