[postgis-tickets] [PostGIS] #2588: GeometryCollection constructor parse defect for sub geometries (POINTM, POLYGONM, ...) of GEOMETRYCOLLECTIONM
trac at osgeo.org
Thu Dec 26 14:05:23 PST 2013
(POINTM,POLYGONM,...) of GEOMETRYCOLLECTIONM
Reporter: bergun | Owner: delawen
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: java | Version: trunk
Keywords: GEOMETRYCOLLECTIONM jdbc POINTM POLYGONM |
Comment(by bergun):
I have attached patch which resolves the issue. The subgeoms outerWKT
method was called with haveM false I changed them to true. This change was
introduced with changeset 1417. When I make this change all the outerWKT
is called with haveM true within the jdbc postgis project. And it looks
like there is no need for 2 signature for outerWKT method. But I keep it
as it is for backward compatibility. Our problem datanucleus unit test is
now running as expected.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2588#comment:1>
