[postgis-tickets] [PostGIS] #2589: HP-UX aCC - rt_api.c compilation fails for void pointer arithmetic
PostGIS trac at osgeo.org
Fri Dec 27 03:05:30 PST 2013
 Reporter:  HAkhtar                                 |       Owner:  pramsey
     Type:  defect                                  |      Status:  new
 Priority:  medium                                  |   Milestone:  PostGIS 2.0.5
Component:  postgis                                 |     Version:  2.0.x
 Keywords:  aCC HP-UX Compilation Failure rt_api.c  |
 I have found that PostGIS is not getting compiled on HPUX with aCC
 compiler.
 PostGIS compilation is failing with the following error:
 "rt_api.c", line 8446: error #2852: expression must be a pointer to a
 complete object type
                                                 ptr += (nXValid * ptlen);
 1 error detected in the compilation of "rt_api.c".
 make[2]: *** [rt_api.o] Error 2
 make[2]: Leaving directory `/dev/postgis/postgis/raster/rt_core'
 make[1]: *** [corelib] Error 2
 make[1]: Leaving directory `/dev/postgis/postgis/raster'
 make: *** [all] Error 1
 GCC works fine at it treats void pointer as char pointer in arithmetic
 operations.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2589>
