[postgis-tickets] [PostGIS] #2170: autogen.sh doesn't work at least for newer autoconf
trac at osgeo.org
Sat Jan 12 10:45:34 PST 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 1.3.7
Component: postgis | Version: 1.3.X
Keywords: |
I just tried to rebuild the 1.3 docs on Debbie and ran into issue that I
can't build from svn.
checking whether ln -s works... no, using cp -p
./configure: line 3160: syntax error near unexpected token `"(('
./configure: line 3160: `case "(($ac_try" in'
make: *** [config.status] Error 2
checking for gcc... gcc
I thought it might be just debbie or change I just made to doc folder so I
tried on my own windows 7 Msys 1.0 and got the same error and then tried
tags/1.3.6 and got the same error. So I then tried the 1.3.6 tar ball on
my local and that worked.
Issue I am guessing is autoconf because building from the tar ball where
sh autogen.sh is not required the configure works fine.
It's only if you build the configure yourself and the issue even in the
1.3.6 tagged version is there. So somehow Hudson/Paul were able to build
the tar balls and docs perhaps because they are running with an older
autoconf is my guess.
anyrate not sure how to fix this since that is one of the areas I consider
magic blackboxed.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2170>
