[postgis-tickets] [PostGIS] #2171: installation of postgis failed on Windows 64
trac at osgeo.org
Mon Jan 14 05:22:34 PST 2013
Reporter: fahar | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: build/upgrade/install | Version: 2.0.x
Keywords: windows |
Comment(by fahar):
Replying to [comment:4 robe]:
> Okay. You are using the wrong downloader if you used the 32-bit. You
need to use the 64-bit version (
http://download.osgeo.org/postgis/windows/pg92/postgis-
pg92x64-setup-2.0.1-1.exe ). The 32-bit gives that error if you try to
install on a 64-bit PostgreSQL.
Is by design?
If User want to install PostgreSQL 9.2 64bit installer and install potgis
32 bit installer, installation proceed and during installation postgis
failed.
I think, It would be better if you add a pop up message, we can not
install 32 bit installer on Windows 64 platform.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2171#comment:6>
