[postgis-tickets] [PostGIS] #2171: installation of postgis failed on Windows 64
trac at osgeo.org
Mon Jan 14 05:47:12 PST 2013
Reporter: fahar | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.3
Component: build/upgrade/install | Version: 2.0.x
Resolution: invalid | Keywords: windows
Changes (by robe):
* status: new => closed
* resolution: => invalid
Comment:
If you used EDB stackbuilder you shouldn't have gotten the option to
install the 32-bit because it would only give you the 64-bit to download.
Why didn't you use that or did you and ran into issue? It sounds like you
went thru the trouble of opening up stack builder. So I was a bit puzzled
by that step that you then went to the PostGIS download site.
If stackbuilder is pointing you at the 32-bit installer when you are
installing on 64-bit PostgreSQL, then that is a BIG concern to me.
As far as the pop up message for if you install 32-bit vs 64-bit
unfortunately its not so easy to popup a message without throwing in a lot
of logic to do SELECT version() this that and another and is more likely
to cause more damage than good.
The main issue why I can't do that is that many people on 64-bit
rightfully have 32-bit installations of PostgreSQL and may very well
install such installation in an unconventional place. There is no easy
way for the PostGIS installer to easily know that without building in a
lot of select PostgreSQL version this that and another. If you get it
from EDB stackbuilder, it should only offer you the 64-bit because it
knows which version you have installed where.
I'm marking this ticket as invalid, but if your main issue is that EDB
stackbuilder gave you a 32-bit download, then reopen since that is a BIG
problem if it is true.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2171#comment:7>
