[postgis-tickets] [PostGIS] #2173: ST_Split fails to split on existing vertex
trac at osgeo.org
Tue Jan 15 01:43:34 PST 2013
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: postgis | Version: 2.0.x
Keywords: |
This bug was found in #2172 as it affects topology building.
In that case a line (899.112421269008 units long) gets splitted by one if
its vertices which is around halfway into it:
select st_line_locate_point(geom, st_pointn(geom, 745))
from offending;
0.692338478022024
The return from ST_Split, unioned back togheter, does NOT give the
original geometry back.
This is most likely due to the fact that the split is not occurring
exactly where the original vertex is but rather on a close-by point which
results in snapping a segment on the new point.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2173>
