[postgis-tickets] [PostGIS] #2175: Adding the same closed line to topology twice creates two nodes
trac at osgeo.org
Tue Jan 15 07:37:46 PST 2013
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.3
Component: topology | Version: 2.0.x
Keywords: |
As found in ticket #2172 adding a closed line to a topology using
TopoGeo_AddLineString two times creates a second node being the leftmost
(and lowermost) vertex in the closed line.
This is due to the way noding with existing edges is performed.
It is not necessarely a bug but can be annoying as it produces a more
complex topology that needed.
In order to fix this there should be a primitive function for rotating a
closed linestring so to start/end on a given point
number. I don't think we have one, do we ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2175>
