[postgis-tickets] [PostGIS] #1627: package tiger_geocoder as a PostgreSQL extension
trac at osgeo.org
Wed Jan 16 01:37:43 PST 2013
Reporter: robe | Owner: robe
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.1.0
Component: tiger geocoder | Version: trunk
Resolution: fixed | Keywords: history
Changes (by robe):
* keywords: => history
* status: assigned => closed
* resolution: => fixed
Comment:
I've updated the docs.
http://postgis.net/docs/manual-
dev/postgis_installation.html#install_tiger_geocoder_extension
Nice thing about extensions is that if you forget the dependencies it
won't let you install and will warn you with a "extension requires
fuzzystrmatch" etc.
I'm going to close this out and create a separate ticket to create an
upgrade path. That will take me more time to write up and test.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1627#comment:5>
