[postgis-tickets] [PostGIS] #2176: ST_ChangeEdgeGeom: exception on SymDifference
PostGIS trac at osgeo.org
Wed Jan 16 01:39:02 PST 2013
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.3
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by ppll):
 Replying to [comment:2 strk]:
 > What's needed for this case is simplified data, starting from the
 geometry of the initial edge and of the simplified edge. Hopefully Paolo
 can provide that.
 This is the call, topo name and edge id are just copy paste
 SELECT topology.ST_ChangeEdgeGeom('eu_geom_35_topo', 81018,
 SimplifyUTM(geom, 35))
 FROM eu_geom_35_topo.edge WHERE edge_id = 81018;
 In the attached file there is the original geometry, SimplifyUTM function
 definition and the geometry after  SimplifyUTM call, all geometries are
 EWKB format.
 Simplifyutm calls utmzone, it's the same function found in the postgis
 book, anyway here is the code from my instance:
 CREATE OR REPLACE FUNCTION public.utmzone(geometry)
   RETURNS integer AS
 $BODY$
  DECLARE
      geomgeog geometry;
      zone int;
      pref int;
  BEGIN
      geomgeog:= ST_Transform($1,4326);
      IF (ST_Y(geomgeog))>0 THEN
         pref:=32600;
      ELSE
         pref:=32700;
      END IF;
      zone:=floor((ST_X(geomgeog)+180)/6)+1;
      RETURN zone+pref;
  END;
  $BODY$
   LANGUAGE plpgsql IMMUTABLE
   COST 100;
 Tell me if you need other data or details. Apologies if I made any mistake
 with the bug report system, first time I use it.
 Paolo
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2176#comment:4>
