[postgis-tickets] [PostGIS] #2180: Postgres crashes on insert statement
trac at osgeo.org
Fri Jan 18 00:33:25 PST 2013
Reporter: MarkRobinson | Owner: strk
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.3
Component: build/upgrade/install | Version: 2.0.x
Keywords: windows64 9.1 |
Changes (by robe):
* keywords: => windows64 9.1
* owner: robe => strk
* component: buildbots => build/upgrade/install
Comment:
odd though. I wonder if its a bug in 9.1.4. That's the only piece I
didn't test that you had. I'll keep this open until I confirm with 9.1.4
since if that is the case, it is probably something that needs to be
reported upstream to the PostgreSQL group possibly an issue with how it
handles throwing errors.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2180#comment:5>
