[postgis-tickets] [PostGIS] #1668: ST_AsText, ST_AsEWKT under Windows 64-bit PostGIS 64-bit is all screwy
trac at osgeo.org
Sun Jan 20 17:09:41 PST 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: mingw64 |
Comment(by woodbri):
robe,
I found this:
> To sum up:
> 1. 32-bit compiler from mingw.org project - defines __MINGW32__
> 2. 32-bit compiler from mingw-w64.sf.net - defines __MINGW32__
> 3. 64-bit compiler from mingw-w64.sf.net - defines both __MINGW32__ and
> __MINGW64__
at
http://www.nntp.perl.org/group/perl.perl5.porters/2009/10/msg152622.html
this might be helpful to add in a conditional compile based on platform.
You can combine with the above WIN32 to determine if you are on a Windows
platform because in theory can't you use mingw to compile for other
systems?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1668#comment:49>
