[postgis-tickets] [PostGIS] #1075: Too much info in address breaks geocoder
trac at osgeo.org
Tue Jan 29 05:48:53 PST 2013
Reporter: mikepease | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: tiger geocoder | Version: trunk
Keywords: |
Changes (by robe):
* version: 1.5.X => trunk
* milestone: PostGIS Future => PostGIS 2.1.0
Comment:
Steven,
thanks for the work on the parser, got it to compile and install on my
ming32. Haven't tried yet on my ming64 but I assume since that is what you
are using, there should be no issue. I'm a bit puzzled by the
standardizer. How do I get it to give the abbreviated.
e.g
select * from standardize_address(
'select seq, word::text, stdword::text, token from lex order by
id',
'select seq, word::text, stdword::text, token from gaz order by
id',
'select * from rules order by id',
'select 0::int4 as id, ''156 Galewski Dr Airport Industrial
Park''::text as micro, ''Winona, MN 55987''::text as macro');
Yields:
id | building | house_num | predir | qual | pretype |
name |
suftype | sufdir | ruralroute | extra | city | state | country |
postcode
| box | unit
0 | AIRPORT INDUSTRIAL PARK | 156 | | | |
GALEWSKI |
DRIVE | | | | WINONA | MINNESOTA | |
55987
Anyway going to start putting in tickets to integrate the PAGC parser.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1075#comment:4>
