[postgis-tickets] [PostGIS] #2193: Utilize PAGC parser as drop in replacement for tiger normalizer
trac at osgeo.org
Tue Jan 29 16:57:10 PST 2013
Reporter: robe | Owner: robe
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: tiger geocoder | Version: trunk
Keywords: |
Comment(by woodbri):
That name is fine. I imagine we will be building more specific tables as
needed and I structure my Tiger data a lot differently than I think you
do. I have C code that denormalizes the Tiger data into single side
records so a single TLID might generate 1+ records if it has multiple
sides, address ranges and city names associated to it.
I built and installed pg 9.2 using mingw64 but didn't use the debug flags.
Typically stuff that works with debug and not optimized indicates one of
two things:
* the optimizer is broken in the compiler
* the code being compiled is broken and overwriting something
I could be wrong, but I thought the later is fairly common with 64 bit
stuff because things (structures) need to be aligned on 8 byte boundaries
and padded where are most 32 bit compilers don't have that requirement.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2193#comment:6>
