[postgis-tickets] [PostGIS] #2293: crash on ST_DumpPoints with curved geoms
PostGIS trac at osgeo.org
Fri May 3 00:58:40 PDT 2013
 Reporter:  robe     |       Owner:  nw
     Type:  defect   |      Status:  assigned
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Changes (by nw):
  * owner:  pramsey => nw
  * status:  new => assigned
Comment:
 Will do.  IIRC, the original function essentially ignored curved types.
 What exactly *should* be the behavior here?  Dump what I assume are
 the control points?  Return NULL?  Return an empty array?  Throw
 an exception?  Interpolate points along the curve?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2293#comment:7>
