[postgis-tickets] [PostGIS] #2293: crash on ST_DumpPoints with curved geoms
PostGIS trac at osgeo.org
Fri May 3 01:03:00 PDT 2013
 Reporter:  robe     |       Owner:  nw
     Type:  defect   |      Status:  assigned
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by strk):
 I think you should dump the points (which I believe are 3 points-on-curve
 per segment).
 But the crash suggests there's a memory error somewhere, as it should
 still be possible to ignore unsupported geometries without crashing. So I
 think you should first make it stable w/out supporting curves and only
 later, if you want, add support for the curve.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2293#comment:8>
