[postgis-tickets] [PostGIS] #2293: crash on ST_DumpPoints with curved geoms
trac at osgeo.org
Fri May 3 17:40:11 PDT 2013
Reporter: robe | Owner: nw
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Comment(by nw):
I have attached a patch made with 'git diff' that
adds two tests on curved geometry to the dumppoints
regression test, and changes the behavior to throw
a data exception in case of unknown or unhandled
geometries. It passes a make check on my system,
which is postgresql 9.2.4, on a 64 bit AMD linux
system. I don't think there's anything about
the code that would cause it to behave differently
in a different environment.
I would be happy to have it dump out the control
points for curved geoms, but (per suggestion) let's
open a different ticket for that.
Given that I tried to duplicate exactly the behavior
of the plpgsql dumppoints function, I think that
throwing an error here may be a change in behavior.
In any case, the behavior should be documented. I can
submit a doc patch if needed and desired, though I will
need to install some more software to build the docs.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2293#comment:11>
