[postgis-tickets] [PostGIS] #2293: crash on ST_DumpPoints with curved geoms
PostGIS trac at osgeo.org
Fri May 3 18:09:46 PDT 2013
 Reporter:  robe     |       Owner:  nw
     Type:  defect   |      Status:  assigned
 Priority:  blocker  |   Milestone:  PostGIS 2.1.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 That's fine (I can add that to disclaimer of docs).  I thought the old
 ST_DumpPoints did dump curved geoms so that sounds like a breaking change.
 I could be wrong though.  I'll test on my old 2.0 and if that is the case,
 we'd probably want to get it in 2.1 (since it doesn't change the API and
 is a breaking change from 2.0), it would be marked as a bug fix rather
 than an enhancement so doesn't have to be done before our 2.1 beta
 release.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2293#comment:12>
