[postgis-tickets] [PostGIS] #2254: Add SFCGAL support
trac at osgeo.org
Sun May 5 11:00:10 PDT 2013
Reporter: colivier | Owner: colivier
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: CGAL, SFCGAL |
Comment(by colivier):
2 & 3) SFCGAL behave as an optional library to be activated on PostGIS
compile time (like json lib for instance)
So yes if you did not choosed it on install time, you have to
reinstall PostGIS binary.
The previous schema stuff obliged the end user to know wich
library provide each function
This point was discussed on Boston too, and if you want it back
you have to convince Paul :)
And OK i will check with 9.3 too
(run_test: it's only a local change in my copy for locale issues
and this obviously will not be commited)
Thanks for you detailled code review !
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2254#comment:11>
