[postgis-tickets] [PostGIS] #2254: Add SFCGAL support
trac at osgeo.org
Sun May 5 11:32:05 PDT 2013
Reporter: colivier | Owner: colivier
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: CGAL, SFCGAL |
Comment(by robe):
2 & 3) hmm okay. It's not ideal but livable. since they are packaged
together and since you have the scgal functions compiled into postgis-2.1
lib I guess it will be obvious to folks when the extension can't install
so not as bad as bad as our GEOS version issues.
Also make sure to test without configuring with sfcgal to make sure all
tests past.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2254#comment:12>
