[postgis-tickets] [PostGIS] #2254: Add SFCGAL support
trac at osgeo.org
Sun May 5 17:13:14 PDT 2013
Reporter: colivier | Owner: colivier
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: CGAL, SFCGAL |
Comment(by robe):
slight correction --- I see you do have a
--with-sfcgal=PATH
So you can keep the without-sfcgal for the case where people have cgal
libraries but don't want them used. Which could be the case for package
maintainers building various flavors.
However the default behavior should be
if you can't find sfcgal and its not specified in --with-sfcgal, then just
don't build with it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2254#comment:17>
