[postgis-tickets] [PostGIS] #2313: CUnit failure for force_sfs
PostGIS trac at osgeo.org
Thu May 9 19:58:06 PDT 2013
 Reporter:  dustymugs  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.1.0
Component:  postgis    |     Version:  2.0.x
 Keywords:             |
 On OSX 10.6, I'm getting the following when running the CUnit tests.
 Suite: force_sfs
   Test: test_sfs_11 ...cu_tester(50125) malloc: *** error for object 0x3:
 pointer being freed was not allocated
 *** set a breakpoint in malloc_error_break to debug
 make[2]: *** [check] Abort trap
 make[1]: *** [check] Error 2
 make: *** [check] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2313>
