[postgis-tickets] [PostGIS] #2332: ST_GeomFromWKB crashes PostgreSQL server
PostGIS trac at osgeo.org
Thu May 16 04:37:31 PDT 2013
 Reporter:  dbaston  |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:           |
Comment(by robe):
 On closer inspection -- I think its something wrong with the way PostGIS
 parser is throwing errors (which for whatever reason only PostgreSQL
 9.2x64-bit is sensitive to).
 The reason I say this is that the same function for geography which is
 defined in exactly the same way works just fine on my 9.2 64-bit
 2.1.0beta2 and just throws the:
 SELECT
 st_geogfromwkb('0104000020E61000000100000001010000008812F4177AE557C040745E6397943D40'::bytea);
 ERROR:  Invalid endian flag value encountered.
 regardless how many times I run it.
 It too is defined with immutable strict
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2332#comment:3>
