[postgis-tickets] [PostGIS] #2332: ST_GeomFromWKB crashes PostgreSQL server
trac at osgeo.org
Thu May 16 07:41:07 PDT 2013
Reporter: dbaston | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by robe):
What the frig?
SELECT
st_geomfromewkb('0104000020E61000000100000001010000008812F4177AE557C040745E6397943D40'::bytea);
Doesn't crash and on closer inspection st_geomfromewkb uses the C
function? LWGEOMFromWKB which directly calls lwgeom_from_wkb:
http://postgis.net/docs/doxygen/2.1/d0/d92/lwin__wkb_8c_source.html#l00724
While The bad ST_GeomFromWKB uses: the C function LWGEOM_from_WKB which
calls LWGEOMFromWKB
http://www.postgis.net/docs/doxygen/2.1/da/d94/lwgeom__ogc_8c_source.html#l00790
and the result check seems to be doing nothing as result is always NULL.
So what the hell is that doing?
That aside why isn't this just directly calling lwgeom_from_wkb like the
good function is?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2332#comment:4>
