[postgis-tickets] [PostGIS] #2333: Can't compile under mingw64 (neither mingw64 or mingw32)
trac at osgeo.org
Mon May 20 11:12:31 PDT 2013
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: sfcgal | Version: trunk
Keywords: |
Comment(by robe):
Currently focussed on the mingw64-w32 and will revisit the other later. I
bumped up to boost 1.53 which is supposed to have all the mingw issues
fixed from what I've read, but sadly still failing at linker when it gets
to building the SFCGAL.dll
undefined reference to
`_imp___ZN5boost6detail12set_tss_dataEPKvNS_10shared_ptrINS0_20tss_cleanup_functionEEEPvb'
I think static building might be my issue so trying to switch boost to
dynamic in cgal and sfcgal.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2333#comment:4>
