[postgis-tickets] [PostGIS] #2333: Can't compile under mingw64 (neither mingw64 or mingw32)
trac at osgeo.org
Mon May 20 23:54:19 PDT 2013
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: sfcgal | Version: trunk
Keywords: |
Comment(by hmercier):
This symbol is part of boost thread. Apprently cmake finds it, so it
should work.
But, yes I never tried with a static boost, only a dynamic linked one,
should be that.
If you still have compiling/linking issues, could you use 'make VERBOSE=1'
and copy the last lines in order to have the real compiler command line
that is called ?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2333#comment:5>
