[postgis-tickets] [PostGIS] #2185: Geometry output functions crash server with invalid WKT
PostGIS trac at osgeo.org
Mon May 20 20:13:42 PDT 2013
  Reporter:  mwtoews  |       Owner:  pramsey
      Type:  defect   |      Status:  closed
  Priority:  blocker  |   Milestone:  PostGIS 2.0.4
 Component:  postgis  |     Version:  2.0.x
Resolution:  fixed    |    Keywords:  windows 64
Comment(by dustymugs):
 As pramsey indicates, this is a subtle bug. The interaction between
 PG_PARSER_ERROR() and PG_RETURN_NULL() somehow works around the issue.
 What's super strange is that if you were to try...
 PG_PARSER_ERROR(lwg_parser_result);
 elog(NOTICE, "I'm a little teapot");
 PG_RETURN_NULL();
 the NOTICE will not fire.
 I can't seem to find a way to run a debugger with EDB and PostGIS which is
 quite... annoying... more experimenting to do... maybe substitute the
 actual code for the macros.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2185#comment:46>
