[postgis-tickets] [PostGIS] #2185: Geometry output functions crash server with invalid WKT
trac at osgeo.org
Mon May 20 21:50:28 PDT 2013
Reporter: mwtoews | Owner: pramsey
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Resolution: fixed | Keywords: windows 64
Comment(by robe):
Might be easier to debug the ereport one: Note: I put PG_RETURN_NULL(); in
two spots in r11481.
The first spot was to prevent ST_AsText('') from crashing and that one
doesn't even go thru the parser -- just uses ereport. A lot of the
crashes I've been seeing so far usually occur when an ereport(ERROR) is
done and as you said in theory no return should need to be made.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2185#comment:47>
