[postgis-tickets] [PostGIS] #2344: Changing in regress caused winnie to scream
PostGIS trac at osgeo.org
Mon May 27 08:53:43 PDT 2013
 Reporter:  robe       |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  blocker    |   Milestone:  PostGIS 2.1.0
Component:  buildbots  |     Version:  trunk
 Keywords:             |
Comment(by robe):
 nope.  The ming system diff does support that flag though --strip-
 trailing-cr.
 I'll try manually to run diff with that flag to see if it works.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2344#comment:7>
