[postgis-tickets] [PostGIS] #2344: Changing in regress caused winnie to scream
PostGIS trac at osgeo.org
Mon May 27 09:01:09 PDT 2013
 Reporter:  robe       |       Owner:  strk
     Type:  defect     |      Status:  assigned
 Priority:  blocker    |   Milestone:  PostGIS 2.1.0
Component:  buildbots  |     Version:  trunk
 Keywords:             |
Comment(by robe):
 I just tried running this:
 diff --strip-trailing-cr Point.select.expected  test_1_out > test.diff
 and works fine under ming environment, but your code is still broken - its
 not producing the same thing
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2344#comment:8>
