[postgis-tickets] [PostGIS] #2516: [raster] Debbie failing on GDAL_Trunk PostGIS regress
trac at osgeo.org
Fri Nov 1 10:47:14 PDT 2013
Reporter: robe | Owner: dustymugs
Type: defect | Status: assigned
Priority: critical | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
Comment(by dustymugs):
Thanks warmerdam.
I plan on testing what happens if non-spatially referenced input rasters
and geometries are made to be spatially referenced (faked). If the tests
work, you should be able to undo r26578.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2516#comment:12>
