[postgis-tickets] [PostGIS] #2531: Autogenerate the extension unpackaged script
PostGIS trac at osgeo.org
Wed Nov 6 07:23:07 PST 2013
 Reporter:  robe                   |       Owner:  strk
     Type:  enhancement            |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Description changed by robe:
Old description:
> Right now before release, we generate the unpackaged scripts used to
> CREATE EXTENSION postgis FROM unpackaged;
> by installing postgis with CREATE EXTENSION and then running a query to
> see what is in the package.  strk is working on script to generate the
> unpackaged script by sourcing the .sql files we generate.  This will
> simplify our packaging logic and also ensure the unpackaged is always in
> synch at all times.
> For testing the quality of it I propose as part of installcheck
> 1. Count number of objects before PostGIS install
> 2. Install PostGIS using non-extension scripts
> 3. Run the generated CREATE EXTENSION postgis FROM unpackaged;
> 4. Run DROP EXTENSION postgis;
> 5. The number of objects in data install should be the same as 1
New description:
 synch at all times.
 (postcheck) #2358
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2531#comment:1>
