[postgis-tickets] [PostGIS] #2531: Autogenerate the extension unpackaged script
PostGIS trac at osgeo.org
Wed Nov 6 07:20:03 PST 2013
 Reporter:  robe                   |       Owner:  strk
     Type:  enhancement            |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 2.2.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
 Right now before release, we generate the unpackaged scripts used to
 CREATE EXTENSION postgis FROM unpackaged;
 by installing postgis with CREATE EXTENSION and then running a query to
 see what is in the package.  strk is working on script to generate the
 unpackaged script by sourcing the .sql files we generate.  This will
 simplify our packaging logic and also ensure the unpackaged is always in
 synch at all times.
 For testing the quality of it I propose as part of installcheck
 1. Count number of objects before PostGIS install
 2. Install PostGIS using non-extension scripts
 3. Run the generated CREATE EXTENSION postgis FROM unpackaged;
 4. Run DROP EXTENSION postgis;
 5. The number of objects in data install should be the same as 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2531>
