[postgis-tickets] [PostGIS] #2532: Unexisting commutator operators for raster
trac at osgeo.org
Wed Nov 6 08:14:36 PST 2013
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.1
Component: raster | Version: 2.0.x
Keywords: |
Operator ~ (geometry, raster) defines @ as the commutator, but there is no
operator @ (raster, geometry) defined.
Operator ~ (raster, geometry) defines @ as the commutator, but there is no
operator @ (geometry, raster) defined.
Those operators seem to be implicitly defined by PostgreSQL, due to the
COMMUTATOR specification, but the script analyzing the .SQL fails to
realize such an object exists and thus fails to drop/upgrade/add-to-
extension (depending on the script output).
If the script is the only issue I guess I could improve the script to deal
with the case, but I'm not sure if there are other consequences.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2532>
