[postgis-tickets] [PostGIS] #1678: [raster] GDAL_DATA dependency
    trac at osgeo.org
    Wed Nov  6 11:44:01 PST 2013
  Reporter:  robe    |       Owner:  pracine
      Type:  defect  |      Status:  reopened
  Priority:  medium  |   Milestone:  PostGIS 2.2.0
 Component:  raster  |     Version:  trunk
Resolution:          |    Keywords:  history
Changes (by edechaux):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 I have tested this fix on postigs 2.1.0 and postgresql 9.2.4.
 While using the parameter '''postgis.gdal.datapath''' from a pqsql session
 works, the double dot in the name prevents it from being set in the
 postgresql.conf file. Upon pg startup, the following error is shown :
 LOG:  syntax error in file "/home/edechaux/test_postgis/postgresql.conf"
 line 574, near token "postgis.gdal.datapath"
 FATAL:  configuration file "/home/edechaux/test_postgis/postgresql.conf"
 contains errors
 I suggest the parameter name to be changed to '''postgis.gdal_datapath'''.
 The pg server starts up without warning/error and the parameter is still
 working properly :
 edechaux=# select current_setting('postgis.gdal_datapath');
            current_setting
  /appli/pgsql/idicsi_2.0/share/gdal/
 (1 row)
 edechaux=# select postgis_full_version();
  POSTGIS="2.1.0 r11822" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
 March 2012" GDAL="GDAL 1.10.1, released 2013/08/26" LIBXML="2.7.6"
 LIBJSON="UNKNOWN" TOPOLOGY RASTER
 (1 row)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1678#comment:19>
