[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
trac at osgeo.org
Wed Nov 6 20:35:59 PST 2013
Reporter: strk | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.1.1
Component: build/upgrade/install | Version: 2.1.x
Resolution: invalid | Keywords: extension
Changes (by robe):
* status: new => closed
* resolution: => invalid
Comment:
strk,
I'm going to dismiss this as wontfix. I just realized now the reason you
got "topology" is not a member of extension is valid and expected.
In the above as you said you are not installing from unpackaged at all,
you are trying to install postgis anew and postgis_topology anew and there
is no way for the extension model to know you already have postgis
installed.
So the error you get
"ERROR: table "topology" is not a member of the extension being created "
means you are trying to install topology and it is failing at packaging it
already exists as not part of package.
The correct steps are
CREATE EXTENSION postgis FROM unpackaged version '2.0.4';
CREATE EXTENSION postgis_topology FROM unpackaged version '2.0.4';
ALTER EXTENSION postgis UPDATE TO "2.1.0";
ALTER EXTENSION postgis_topology UPDATE TO "2.1.0";
and that works for me. I will say that we could have documented the
behavior better and there is an issue with me dropping the postgis
extension without doing a drop cascade. I think that issue though is
because of wholes in my unpackaged script which should be fixed by your
updated one.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2503#comment:9>
