[postgis-tickets] [PostGIS] #2535: Add safety logic to EXTENSION scripts to avoid misuse
PostGIS trac at osgeo.org
Thu Nov 7 04:51:19 PST 2013
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  postgis      |     Version:  trunk
 Keywords:               |
Changes (by robe):
  * owner:  pramsey => strk
Comment:
 I don't think you can do that because then you can't upgrade it.
 I think you just have to in the unpackaged script run the check script
 version and return an error if it fails.  Since the package scripts are
 run in a transaction, I think the script will just bail out.
 In theory this should be pretty much a non-issue if done right, because
 since we add new functions on each minor, the unpackaged script for the
 current version would fail anyway because it would try to add a function
 not in current users install and then bail when it can't find it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2535#comment:3>
