[postgis-tickets] [PostGIS] #1678: [raster] GDAL_DATA dependency
trac at osgeo.org
Fri Nov 8 05:06:33 PST 2013
Reporter: robe | Owner: pracine
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Resolution: fixed | Keywords: history
Comment(by edechaux):
Replying to [comment:22 dustymugs]:
> So this problem only happens for setting the value in postgresql.conf?
Within a session, this has no issues (due to behavior exhibited in the
regression tests).
Yes, allowing the parameter to be used in the configuration file will
allow any application to use postgis/gdal by default, without needing to
set a session parameter.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1678#comment:23>
