[postgis-tickets] [PostGIS] #2546: GeoJSON with string coordinates parses incorrectly instead of throwing error
trac at osgeo.org
Wed Nov 20 03:59:54 PST 2013
error
Reporter: crschmidt | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.0.x
Keywords: |
SELECT
ST_AsText(ST_GeomFromGeoJSON('{"type":"Point","coordinates":[-48.23456,20.12345]}'))
returns POINT(-48.23456 20.12345)
SELECT
ST_AsText(ST_GeomFromGeoJSON('{"type":"Point","coordinates":["-48.23456","20.12345"]}'))
returns POINT(-48 20)
Although the data in the second example is *wrong* -- coordinates
shouldn't be enclosed in strings -- it seems an odd choice to truncate the
values instead of just reporting an error back to the user. (I think
parsing them as floats would also be reasonable, but I wouldn't say it's
at all a requirement.)
This was brought up by timbunce in the GeoJSON channel; he had a login
issue so I am reporting on his behalf.
POSTGIS="2.0.3 r11128" GEOS="3.3.8-CAPI-1.7.8" PROJ="Rel. 4.8.0, 6 March
2012" LIBXML="2.7.6" LIBJSON="UNKNOWN"
Adding on Tim's behalf as well (I personally disagree):
"< timbunce_> Please add a note to the case that supporting coords in
string form would make life a lot easier for people working in dynamically
typed languages where the string/number distinction is subtle."
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2546>
