[postgis-tickets] [PostGIS] #2547: ST_Simplify(TopoGeometry) doesn't simplify hierarchical topogeoms
PostGIS trac at osgeo.org
Thu Nov 21 08:09:48 PST 2013
 Reporter:  duncandoo                       |       Owner:  strk
     Type:  defect                          |      Status:  new
 Priority:  medium                          |   Milestone:  PostGIS 2.1.2
Component:  topology                        |     Version:  2.1.x
 Keywords:  st_simplify topology hierarchy  |
 Running the topogeom version of ST_Simplify() on a topogeomery layer that
 is a parent layer I get the following error:
 ERROR:  function topology.st_simplify(topogeometry) does not exist
 LINE 1: SELECT st_multi(st_union(topology.ST_Simplify(topogeom))) as...
 HINT:  No function matches the given name and argument types. You might
 need to add explicit type casts.
 QUERY:  SELECT st_multi(st_union(topology.ST_Simplify(topogeom))) as geom
 FROM public.alsace, alsace_topo.relation pr WHERE  pr.topogeo_id = 2 AND
 pr.layer_id = 2 AND  id(topogeom) = pr.element_id  AND layer_id(topogeom)
 = pr.element_type
 CONTEXT:  PL/pgSQL function st_simplify(topogeometry,double precision)
 line 59 at EXECUTE statement
 ********** Error **********
 SQL state: 42883
 Hint: No function matches the given name and argument types. You might
 Context: PL/pgSQL function st_simplify(topogeometry,double precision) line
 And here is the SQL I run to get the error:
 CREATE DATABASE france;
 CREATE EXTENSION postgis;
 CREATE EXTENSION postgis_topology;
 --Use QGis to import shape file from
 http://www.actualitix.fr/actgeoshap/regions/alsace.zip
 SET search_path to public, topology;
 SELECT CreateTopology('alsace_topo', find_srid('public', 'alsace',
 'geom'));
 SELECT AddTopoGeometryColumn('alsace_topo', 'public', 'alsace',
 'topogeom', 'MULTIPOLYGON', (
 SELECT layer_id FROM layer WHERE table_name = 'alsace'
 UPDATE alsace SET topogeom = toTopoGeom(geom, 'alsace_topo', (
 SELECT st_simplify(topogeom, 10000) FROM alsace; -- works
 CREATE TABLE alsace_depts AS SELECT DISTINCT code_dept FROM alsace;
 SELECT topology.AddTopoGeometryColumn('alsace_topo', 'public',
 'alsace_depts', 'topogeom', 'MULTIPOLYGON', (
 UPDATE alsace_depts SET topogeom = createTopoGeom('alsace_topo', 3,
 (SELECT layer_id FROM layer WHERE table_name = 'alsace_depts'), a.tgs)
 FROM
 SELECT code_dept, topoElementArray_agg(array[id(topogeom),(SELECT layer_id
 FROM layer WHERE table_name = 'alsace')]) as tgs
 FROM alsace
 GROUP BY code_dept
 ) a
 WHERE a.code_dept = alsace_depts.code_dept;
 ALTER TABLE alsace_depts ADD COLUMN dept_geom geometry(MultiPolygon,
 2154);
 UPDATE alsace_depts SET dept_geom = topogeom::geometry(MultiPolygon,2154);
 SELECT st_simplify(topogeom, 10000) FROM alsace_depts; -- doesn't work:
 produces error
  I think what the error says is that the function is calling another
 function that doesn't exist (ST_Simplify(topogeom)). Is it supposed to be
 calling the function ST_Simplify(topogeom, double) instead?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2547>
