[postgis-tickets] [PostGIS] #2436: Build a travis test bot
PostGIS trac at osgeo.org
Mon Sep 2 15:32:51 PDT 2013
 Reporter:  robe       |       Owner:  robe
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  Management 2.0
Component:  buildbots  |     Version:  2.0.x
 Keywords:             |
Comment(by robe):
 update got a travis build using Getty's script and added a libjson-dev to
 it
 https://travis-ci.org/robe2/postgis
 It seems his script fails in 2.2 if you don't install libjson, but it
 worked in 2.1. Getting 3 failures.  I'll post to separate ticket as
 regression bug.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2436#comment:7>
