[postgis-tickets] [PostGIS] #2467: travis regress failure
trac at osgeo.org
Mon Sep 2 15:34:48 PDT 2013
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Keywords: |
This is from my new travis testing (thanks to help from Torsten Raudssus
aka Getty)
Loading PostGIS into 'postgis_reg'
PostgreSQL 9.1.9 on x86_64-unknown-linux-gnu, compiled by gcc
(Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3, 64-bit
Postgis 2.2.0dev - r11909 - 2013-09-02 22:21:19
GEOS: 3.4.1-CAPI-1.8.0 r3892
PROJ: Rel. 4.7.1, 23 September 2009
Running tests
loader/Point .............. ok
loader/PointM .............. ok
loader/PointZ .............. ok
loader/MultiPoint .............. ok
loader/MultiPointM .............. ok
loader/MultiPointZ .............. ok
loader/Arc .............. ok
loader/ArcM .............. ok
loader/ArcZ .............. ok
loader/Polygon .............. ok
loader/PolygonM .............. ok
loader/PolygonZ .............. ok
loader/TSTPolygon ......... ok
loader/TSIPolygon ......... ok
loader/TSTIPolygon ......... ok
loader/PointWithSchema ..... ok
loader/NoTransPoint ......... ok
loader/NotReallyMultiPoint ......... ok
loader/MultiToSinglePoint ......... ok
loader/ReprojectPts ........ ok
loader/ReprojectPtsGeog ........ ok
loader/Latin1 .... ok
loader/Latin1-implicit .... ok
binary .. ok
regress .. ok
regress_index .. ok
regress_index_nulls .. failed (diff expected obtained:
/tmp/pgis_reg/test_27_diff)
regress_selectivity .. ok
lwgeom_regress .. ok
regress_lrs .. ok
removepoint .. ok
setpoint .. ok
simplify .. ok
snaptogrid .. ok
summary .. ok
affine .. ok
empty .. ok
forcecurve .. ok
measures .. ok
legacy .. ok
long_xact .. ok
ctors .. ok
sql-mm-serialize .. ok
sql-mm-circularstring .. ok
sql-mm-compoundcurve .. ok
sql-mm-curvepoly .. ok
sql-mm-general .. ok
sql-mm-multicurve .. ok
sql-mm-multisurface .. ok
polyhedralsurface .. ok
polygonize .. ok
postgis_type_name .. ok
geography .. ok
out_geometry .. ok
out_geography .. ok
in_geohash .. ok
in_gml .. ok
in_kml .. ok
iscollection .. ok
regress_ogc .. failed (diff expected obtained: /tmp/pgis_reg/test_60_diff)
regress_ogc_cover .. ok
regress_ogc_prep .. ok
regress_bdpoly .. ok
regress_proj .. ok
regress_management .. ok
dump .. ok
dumppoints .. ok
boundary .. ok
wmsservers .. ok
wkt .. ok
wkb .. ok
tickets .. failed (diff expected obtained: /tmp/pgis_reg/test_72_diff)
typmod .. ok
remove_repeated_points .. ok
split .. ok
relate .. ok
bestsrid .. ok
concave_hull .. ok
hausdorff .. ok
regress_buffer_params .. ok
offsetcurve .. ok
relatematch .. ok
isvaliddetail .. ok
sharedpaths .. ok
snap .. ok
node .. ok
unaryunion .. ok
clean .. ok
relate_bnr .. ok
delaunaytriangles .. ok
in_geojson .. ok
uninstall .. ok (3857)
Run tests: 92
Failed: 3
make[1]: *** [check] Error 3
make[1]: Leaving directory `/home/travis/build/robe2/postgis/regress'
make: *** [check] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2467>
