[postgis-tickets] [PostGIS] #1580: proj4 cache corrupted by projection error ?
trac at osgeo.org
Mon Sep 16 16:08:13 PDT 2013
Reporter: strk | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment(by caleb):
Here you go:
PostgreSQL 9.1.9 on x86_64-unknown-linux-gnu, compiled by gcc
(Ubuntu/Linaro 4.7.2-2ubuntu1) 4.7.2, 64-bit POSTGIS="1.5.3"
GEOS="3.3.3-CAPI-1.7.4" PROJ="Rel. 4.8.0, 6 March 2012" LIBXML="2.8.0"
USE_STATS
I'm using the Ubuntu packaged version, but I'm happy to upgrade to 2.0
manually if that's the easiest fix (sounds like it is).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1580#comment:5>
