[postgis-tickets] [PostGIS] #1580: proj4 cache corrupted by projection error ?
trac at osgeo.org
Mon Sep 16 21:37:06 PDT 2013
Reporter: strk | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment(by robe):
Given you are using packages, I would say upgrade to postgis 2.0 is your
best bet since those are already available via packages. Upgrading to
PostGIS 2.1 would be fine too (same effort as giong to 2.0 if your page
offers it).
Just a warning going from 1.5 to 2.0 requires a hard upgrade. Going from
2.0 to 2.1 is just a soft.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1580#comment:6>
