[postgis-tickets] [PostGIS] #2417: pgsql2shp doesnt see SRID
trac at osgeo.org
Sun Sep 22 09:48:05 PDT 2013
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS Future
Component: documentation | Version: 2.0.x
Resolution: | Keywords: srid, pgsql2shp
Comment(by darkblueb):
another aspect to this is..
Using the general technique of
CREATE TABLE new_table AS
SELECT
pkey, ST_SetSRID( ST_Transform( geom, 4326), 4326)
FROM
existing_valid_table;
new_table's geometry is internally marked SRID=4326
(via {{{lwgeom_set_srid()}}} but new_table geom has no typemod,
so new_table geom does not appear in geometry_columns, or
generally behave as expected.
A second step, explicitly calling {{{UpdateGeometrySRID( new_table, geom,
4326)}}}
sets things right.
An general improvement would to create some single SQL line that would fit
into the CREATE TABLE as SELECT .. mold and document it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2417#comment:7>
