[postgis-tickets] [PostGIS] #2417: pgsql2shp doesnt see SRID
PostGIS trac at osgeo.org
Sun Sep 22 14:26:06 PDT 2013
  Reporter:  darkblueb      |       Owner:  pramsey
      Type:  defect         |      Status:  reopened
  Priority:  medium         |   Milestone:  PostGIS 2.1.1
 Component:  documentation  |     Version:  2.0.x
Resolution:                 |    Keywords:  srid, pgsql2shp
Changes (by robe):
  * milestone:  PostGIS Future => PostGIS 2.1.1
Comment:
 How about this
 CREATE TABLE new_table AS
 SELECT
   pkey, ST_Transform( geom, 4326)::geometry(POINT,4326) As geom
 FROM
   existing_valid_table;
 Does it in one step and registers correctly.
 You could also just pass an sql statement and avoid the whole create table
 step as I noted already.  If you used an SQL statement it would register
 right because it wouldn't find any answer in geometry_columns so as I
 stated before this should work just fine.
 pgsql2shp -f test_shapefile.shp "SELECT * from ne3_test" shp_test
 If you can put together a documentation patch to save me the trouble of
 explaining this that would be really swell.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2417#comment:8>
