[postgis-tickets] [PostGIS] #2485: [raster]: raster constraints prevent raster data from restoring
trac at osgeo.org
Mon Sep 23 23:31:47 PDT 2013
Reporter: rdunklau | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.5
Component: raster | Version: trunk
Keywords: |
Comment(by rdunklau):
In retrospect, it isn't quite as serious as I thought since most people
are lazy and throw postgis and their data in public.
From my experience, many people would be bitten by this. Not because they
throw all postgis data in its own schema, but because there can be postgis
data spread among many of them.
I always emit the SQL from pg_restore (pg_dump in custom format) and
make my necessary changes (usually with a shell script).
As a temporary workaround, could you provide an example of such a script ?
The only thing I could think of was to "sed" the SET search_path command
to include public as well, but I'm sure there could be many unforeseen
side-effects (for user-defined functions, for exemple).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:17>
